My truck (2000 2500 automatic w/103K) has a bad case of dead pedal.I went by Autozone and had them read the codes and the only one was overboost.I cleared it and none have returned.It also has a fairly new fass ddrp lift pump on it.Once in a while it wil take off like normal for 2 or 3 presses of the accelerator; then just return to the same old dead pedal.Can the APPS be checked with a digital volt meter?Any other ideas? probably VP44?thanks in advance.joek
  • 3 weeks later...
