ATTENTION ALL!
I am working on a 04 and cant find the fuel pump relay where is it located?
  • Replies 3
  • Views 2k
So no relay for fuel lift pump. I'm stumped then and looking for ideas here's what its doing it doesn't build power and cel is on the code I'm geting is low voltage at pump nim not convinced the lift pump is bad but I. Am looking for ideas
Whats the code?Possible bad ground at the lift pump which is hidden behind the starter. This requires to remove the starter to service this ground. (At least on the 02 dodge).Possibly a bad lift pump with a heavy load that is pulling the voltage odwn on that circuit because of mechanical problems internally.
Did This Forum Post Help You?
