Failure of the Transmission Heat Exchanger?
Has anyone with an automatic trans had their transmission Heat exchanger (located on the passenger side of the block) fail?If so is this a prone part to fail?The reason im asking is that at 10 years, and 8 year old engine coolant(before i changed it), im wondering if it will stand the test of time, or if i should go about replacing it, and avoiding trashing my fully built transmission.
