Brake Controler Install
I know there is a place to plug in under the dash for the controller but is there a three way plug that can be pluged in in the back somewhere for the plug in the bed for goose neck hook up?Did I splain that right:think:
  • Replies 3
  • Views 1.9k
The brake controller plugs under the dash next to the 100 pin connector. In the bed you have to splice in your own 7 wire connection.
For 65 bucks you can buy the plug in adapter wire kit in bed. Its all plug in and no cutting of wires. Just the box
  • 4 months later...
The previous owner has cut the wiring harness under the dash and hard wired the trailer break control wiring. I am now attempting to install a new trailer break control unit and I would like to repair the previous owners work back to oem. I need the oem end of the plug. Does anyone know where to buy the part?
