- Replies 5
- Views 2.5k
Mopar1973Man 2 posts
jumpjg 2 posts
Baconbitsforu 1 post
My truck is equipped with the tow package and the 7-pin receptacle for trailer lights/brakes/etc. I have an electric brake controller in the cab. The ground (pin #1), left turn/brake light (#5), tail light (#3), right turn/brake (#6) and electric brake (#2) all work. As I understand it, pin #4 (2 o'clock) is used to charge the battery in the RV trailer. I checked the #4 pin with ignition on & it was dead. I looked at the trailer fuse (40 amp) in the power distribution panel under the hood and it looks good. Where else should I look for the disconnect? Also what is the auxiliary pin (#7, in the center) used for & how is it switched?Appreciate your help,Joe in St Louis
