Overload spring cushions on 3500
This truck is so hodge-podge, aftermarket OL packs wouldn't surprise me..
BTW, the Fennco 3" coupler lasted 4 days before it made it's exit.. It was really loose on the contact mount; it probably just fell off..
How do you secure yours to stay?
- - - Updated - - -
I may be imagining things... I have only a 2500/8800gvw... but in the OPs truck: I think I'm seeing a piece of steel above the frame and below the rear body cross members... that the overloads are hitting. Is that part of the bed? I'm not seeing the stops. If I'm seeing it right, this steel would be making contact before the suspension has a chance to work.
Russ, that piece you see is inboard of the actual spring mounts/stops. It's part of the bed..
