20 micron W/F separator in front of Raptor?
I'm not an expert on this, and have decided to install the Fass lift pump on mine at a later date. In checking into this and wanting to do it all at once, I found out this little info when calling Fass. You can install a larger high quality filter before the pump and this will protect it. But it will also make the pump work harder pulling from the tank. They come with a pre-filter that stops debris from the suction inlet, (but not at a very very small micron), thus protecting the gears. Why make it work harder and possibly wear early ?
Don't even have a screen on the Raptor but Glacier said pretty much the same thing about not putting a filter in front of the pump. With all the reports of these things getting debris in the gears and seizing I thought I'd try to prevent it but I guess not. Sent from my iPhone using Tapatalk
I'm not sure of the micron size it handles, but it's the old style metal can style in-line filter they use. You can buy them at AutoZone or Napa all day. They look like the type they used on the 50's and 60's chevy, about 2 1/2" long and 1 1/2" diameter with an inlet / outlet on each side, and very cheap.Sorry, it's an FF3248 and can be bought at Napa. Here's their filter info.
FF 3248.pdf
