- Replies 10
- Views 2.3k
Mopar1973Man 4 posts
FiveNine 3 posts
02cumminsdude 1 post
diesel4life 1 post
I am trying to figure out who to buy an Injection pump from. Most are right around $1,000 give or take $50. I had planned to buy a stealth plate and injector nozzles along with the pump... However, It has been brought to my attention, that any sort of wire tap WILL void the warranty. I have been told that most places sell the same pump, so its areally all about who you like. I really like Moparman's set up with RV275 injectors, and Edge comp box. The comp box is a wire tap box, therefor, No warranty.Questions:1. Who have YOU bought a pump from, and how do you like it?2. How dangerous is a wire tap? 3. What is a good set up for a non-wire tap programmer? 4. I know you "Should" get your injectors pop tested, but what will happen if I dont. If I buy nozzles, and send them out for pop testing, will I have the same or more money in them than if I buy the whole injector from who ever?My goals for the truck is 400ish HP, I know that the general rule of thumb is that the HX35 is good to about 350hp, so I might step up to an HX40 or similar down the road. Who knows..My plans are to take baby steps, So unless I run across a killer deal on a programmer or turbo, I might very well run threw the new VP's warranty period with out a programmer. educate me....
