DSS steering stabilizer & Borgeson steering box
I have a Borgeson steering gear and have recently obtained a DSS steering stabilizer. I have read here that the DSS needs to be modified to work with the steering gear. Does anyone have the details of the modification?
basically, the Borg box is a little bigger, and slightly moved the output shaft about 1/8"-1/4" to the right (IIRC). The brace, you'll need to "slot" the bearing bolt-holes to accommodate this, as well as the bearing's center opening, so that the bearing assembly can slide over a little to center on the shaft..A dremel should suffice.
