How much power steering fluid??
With a dry system I would bet around 2 quarts tops. But the steering box is loaded with fluid, so is the hydro-booster so I would flush the system out with at least a quart with the old pump in before hooking up the new pump. This way the system is clean and your not pumping dirt into your new fresh pump.
