Hey,I'm going to change my power steering pump with a high flow PSC one and put a cooler in line. I'm wondering how much fluid will I need??How much did the stocker hold???Thanks,Winslow
With a dry system I would bet around 2 quarts tops. But the steering box is loaded with fluid, so is the hydro-booster so I would flush the system out with at least a quart with the old pump in before hooking up the new pump. This way the system is clean and your not pumping dirt into your new fresh pump.
