problems with WTS/IAT/ECM
- Replies 10
- Views 4.3k
AH64ID 4 posts
wakerc 4 posts
Mopar1973Man 2 posts
I have searched all over for days and cannot seem to find anything to help that applies to a 3rd gen. Issue: When I try to cold start (after truck sitting all night and it below 40 degrees out) the truck simply wont turnover unless I leave it plugged in all night. i'm talking NOT AT ALL. then I figured out that the WTS light is only staying on for a max of 3 seconds when cold so the grid heater isn't cycling long enough to warm up. it will stay on for the regular 10 seconds but only when the truck is at operating temp and shut it off and immediately turn it back on. What I have done: installed new grid heater, installed new IAT, and monitored IAT readings with scanguage. I found out that when the engine is cold the IAT reading is saying 115-122 degrees. after starting the temp slowly drops down to what is an expected temp. All this was checked when it was around 30 degrees out. Ideas: possible short in wiring harness? dying/confused ECM? Any and all help would be appreciated
