airdog 150 question
so I got a airdog 150 off a cracked block engine. My question is do I need to put a draw straw in my tank or can I use the stock suction line? also the bed will be off the truck as I"m repainting the frame so migth be a good time for tank upgrades? just not sure if the draw straw is the way to go. Thanks
I installed the AD165II with a kit for removing the in tank pump. The kit enlarged the oe fuel line for the 165. I do believe that it would be much better for the 150 to have a draw straw or anything that will give the pump the flow that it needs. The old lines are restrictive and will work the pump that much harder. I don't know what your pump is coming with, but the more you open it up in size from the tank to the vp the better off you will be.
