Can Bed Be Adjusted Side to Side?
I put a headache rack on my bed and discovered the bed is not quite aligned with the cab. Can it be moved slightly from side to side if I loosen the bolts?Thanks,Stew
  • Replies 4
  • Views 1.8k
If memory serves me correctly I think you do have a little bit of movement. Loosen the bolts off and try
Thanks! Guess I know what I'll be doing this afternoon. Stew
Yes, you have a bit of movement in the bed and cab. Get under the truck and measure from the cab to the frame adn the bed to the frame.
Thanks for the help. As it turns out, the cab was offset to the right about 3/4". Loosened the 8 bolts and used a pry bar to move it over. Everything lines up nicely now. Strange though, 4 bolts were 3/4" and 4 of them were 18mm. Stew
