I need help in locating where to purchase the two rods that go into the wheel cylinder for the rear drum brakes.
  • Replies 6
  • Views 1.3k
Probably have to get new wheels cylinders. They are about $10-15 each side. Its the perfect time to upgrade to 1 ton chevy wheel cylinders while your at it. I am using 1995 chevy 1 ton dually wheel cylinders, but make sure they are for a dually and not a 1 ton single wheel as they are the biggest ones.
i need and they do not come with any hardware, I tried the dealer they said they are Discontinued.
- - - Updated - - -
Do you have any idea what chevy years will work? and thank you
Ive never bought a hardware kit for the Dodges but other vehicles Ive done they have been included in the kits. Ask the auto parts store for a spring kit and take a look at it, they should be in there.For the wheel cylinders, Napa part number 37337. They are for a 1 ton Chevy and is a direct bolt in. They were an improvement for me, but I think unhooking the load proportioning valve and cranking it up most of the way helped me as much if not more than the wheel cylinders
Probably a situation where some brands the pins are included and some aren't. I haven't done a set of drums that ever required the pins to be replaced but I haven't lived anywhere that salts the roads thank god. No better way to ruin a perfectly good vehicle. I don't plan on ever buying another truck and I'm only 51, but I don't have to worry about it rotten out from under me.
