Wel gang...
I'm going to show to graphs... First off a bit of history... From day one when I bought the truck I was told by people to get PowerService +Cetane Boost and run that with the truck to protect the IP/LP pumps. I ran PS till 50K mile when I lost my first LP & IP pumps. After losing both of them I start looking at better solutions that PS, MMO, etc... Hence the start of 2 cycle oil research at 85K miles. I din't have the dosing ratio figured out in the early time but by 95K miles I had figured it out!
MPG graph... Take notice the PS up 50K is flat no change and after 95K miles it take off! (2 cycle oil)
Cost per mile... Notice the reducution in cost per mile once I got the ratio figure out for 2 cycle oil!
And if 2 cycle oil is bad for injectors and LP/IP pumps then why is my dyno sheet so good???
Stock mode - 228 HP /462 TQ
Edge Comp 5x5 - 379 HP / 831 TQ
Edge Comp 5x5 - 381 HP / 826 TQ
(8% correction factor)
I've got my truck covered for the entire year. And for those of you that ask how I keep my injectors clean. Simple I change my fuel filter 2K miles early and use QUALITY FILTERS and FUELS! As for ANTI-GEL the 2 cycle oil is rated down to -40*F. I've NOT USED a SINGLE FUEL ADDITIVE, CLEANER, or CETANE BOOSTER since 50K miles... So if my MPG is HIGHIER now why do I need to used such products??? You go figure...
  • 6 months later...
I've got little red x's for pictures on mine...What mixture are you running?I put about half a bottle in my 100gallon tank to get back home once,when my LP started acting up,and after I did that I had some kinda wierd problem,at an idle the truck would act like it had been shut off for about .25 sec,then it would blip back up to 800rpm and run fine,then do it again...it finaly went away,but I never figured what the problem was.
Yeah... I was using pics from the static web site but the pics are now long gone... But I could send you the links to the PDF files that now replace them... :thumbsup http://mopar.mopar1973man.com/cummins/general/better-mpgs/better-mpgs.htm 128:1 ratio is what I normally run... As for what you added or how much to 100 gallons of fuel... :confused: You got me... :rolleyes
