Lift pump replacement instructions ?
Should have my new airdog tomorrow, what do I need to do to get to the lift pump on motor to swap it out ? do I need to remove starter ? or remove fuel filter canister ? or is it accessable as it sets ? any link or info that will make it go ez I will appreciate thnx
  • Replies 1
  • Views 1.7k
Popular Days
Depends on your setup and design you want to take. I kept my stock filter can and still use it today. As for the stock lift pump I can normally change those from the top in about about 15 minutes. So just remove all the stock plumbing from the lift pump and the 3 nuts on top and it will drop on the ground. Then just install your Airdog. Personally I would give Eric a call at Vulcan Performance and see about converting over to old school pushloc's so you don't have a air leak problems. Also this will allow you to add in the fitting to continue using the stock filter can as a secondary catch all filter, keep your fuel heater, etc.
