a little scared to do 60lb springs
- Replies 6
- Views 2.6k
ISX 4 posts
MnTom 1 post
dodgethis91cmns 1 post
Ive never been afraid of doing just about anything to my truck. but this 60lb spring install seems to sound a little sketchy. ive read across all forums and looked on youtube and i have a general idea of how to do it. the only thing im worried about is being ABSOLUTELY sure that im at TDC so my valves dont drop into the cylinder. i was going to try to complete the job tomorrow because i need my truck for work on monday. is there any sure way to tell that i'm at TDC? i've seen the method where you use a dial indicator, (i do not have one)and also the method of pulling the injector (that seems time consuming and i do not have a tool to pull injectors)i was hoping there was a quick easy way just by turning the engine over.
