P1693 & P1596 error codes.
I need some help with a problem I am having. My check engine light has come on on my 01 3500, when I checked the oddy the error codes showed P1596 and 1693. I use the truck as a hotshot and pull some pretty good loads with the truck. I also noticed that my tach would go off and on, when it went off and zeroed out I lost 30%+ in power. As soon as my tach started working, power resumed to normal. I had a buddy of mine run his diagnostic tool on it, btw he's a retired diesel mech, and his equipment show "eng mod" but no error codes. Finally, I did take Michael advise and ran the oddy past the error codes to P-done. It went straight to mileage and showed no more codes. At this point I am pretty much at a lose, only thing I know to do is take it to dodge (cough). Perhaps there equipment will pin point the problem.
  • Replies 2
  • Views 4.7k
2001 trucks require a OBDII error code reader to get the codes.
I would buy or barrow a OBDII code reader and just get the codes. Most all auto part stores with read your codes for free.
I will get down to autozone and see what they got, thanks
http-~~-//www.youtube.com/watch?v=Xt3RQbAKvg4
- - - Updated - - -
I invested in a mid range OBDII and got a P0341 error, camshaft sensor. Going to replace that puppy tomorrow and get that dawg back on the road. The bucks ain't flowin if the wheels ain't rollin!!!
