Snow Performance Water Methnol worth it?
You guys don't see million mile trucks like CajFlynn (resident mil plus miler) running a water/meth injection kit. If you are pushing the engine hard enough towing to need a water injection system you are likely pushing too hard anyway. CajFlynn is a fan of staying below 20psi if I recall correctly. The system also isn't going to help you. You are cooling down the gases in the engine that operates off hot air? Whats the point? It seriously lowers your overall efficiency and methanol isn't cheap, as mentioned. If water/methanol injection was good you would see it more widely used. Historically, it really hasn't been used since the dark ages since our metallurgy has improved. You can get more power temporarily with a water injection system, but it really doesn't help beyond a short term flat out push.
