- Replies 2
- Views 2.6k
Mopar1973Man 1 post
mariner 1 post
I recently installed a new Timbo APPS and everything went fine - that was about five days ago. Truck drove well (improved on OEM) and no CEL.Today I used the truck and got a check engine light come on for the first time ever
.I will check the truck wiring in the morning - too p*ssed off right now to do anything remotely serious.When I checked the codes (using my Autel Maxiscan MS300 ODB11 Code Reader), I got P0216 - Fuel injection pump timing and P0222 - Apps voltage low. The truck runs fine and sounds good - nothing unusual happening so far.Has anyone have an idea of what the P0222 would cause - fuel pump timing error due to low signal voltage?Anything I need to be concerned about regarding low voltage - short term or long term?I am just trying to get a feel for what might be the outcome of the low voltage.I need to go over the wiring with a fine tooth comb.Any suggestions would be appreciated.ThanksmarinerPS - fuel pressure fine at 13 idle, 10 cruise at 60mph and 6 at WOT. New transfer pump ordered recently.
