Dead Batteries
l had dead 2 month old batteries in my 2001. Read through threads on dead batterieshere and found info on IOD fuse #12 in junction box.The shop manual said to disconnect both batteries, connect a amp meter between the ground terminal and ground wire - keeping it connected and wait for 3 minutes then check the fuses and relays. The only drain l had was threw the IOD fuse #12 in the junction box I had a 246 mamp drain threw it. Shop manual said should be less than 30. Used shop manual wiring diagram to narrow it down to lights common to that fuse. It was the glove box light. Disconnected it and the amp draw dropped to 1.64 mamps. :):)
  • Replies 1
  • Views 1.5k
