- Replies 11
- Views 7.3k
MnTom 5 posts
AGPTurbo 5 posts
Yankneck696 1 post
Hi guys,
got the new grid heater battery jumper wire set I had ordered. I put it on, tried it and fried it in 5 seconds- bye bye $40. Anyway, I just followed the troubleshooting instructions here after this disaster:
http://dodgeram.org/tech/dsl/troubleshooting/Maniford_htr.htm
I have .1 or 0 Ohms (depending on the multimeter setting) across the heater grid terminals as stated in the 2002 instructions. But it seems like you wouldn't want 0 if going from the grid terminals to ground as that would in indicate a direct short to ground.
If I jump the grid straight to the battery its like a welder. Anyone have any issues with this before? I took the intake horn off just to check if something was sitting on the grid and it's clear. Im not sure what could be grounding out. I also checked the heavy relay to grid wires and they are fine.
I'm out of ideas and its 10F today and high of 1 and 3 F this week.
Thanks
