For Sale - 2006 Dodge Ram 2500- Flatbed for long box bed Winch bumper Flat Bed for Long Box 3rd generation Cummins Tootlbox are included with key I have a flatbed for 3rd Generation dodge Cummins. This flatbed comes with a gooseneck hitch already in the bed. The winch bumper is part of the set. Tootlbox have a key to lock and unlock all box a single key. There is rust starting and electrical will have to be sorted out on your own.
Price: $1,000.00
Hi guy's, greeting from snowy Michigan! This has been my first winter with the Jr. Cummins up here and I've been very impressed!
No problems at all starting in temps as low as 18 below (Not plugged in) she's impressed the other diesel owners at work aswell , they pretty much don't drive theirs in the winter,and when they do, they all plug them in .
Anyway back on topic- when I rolled into the cottage tonight and flipped off the lights , I noticed that when I had my foot on the brake , my right front turn signal was glowing dimly, let off brake light goes out. So I did a walk around and checked all the lights and everything but a front side marker was working. Right turn signals worked correctly, BUT when I checked the left turn signals (with the headlights off) the right signal and brake light flashed along with it. When the headlights are on , everything seems to work properly..
There haven't been any harness or wire mods that I know of, but the truck has been working in some downright nasty conditions for the last 2-3 months and this seems to scream bad ground, or a fault somewhere to me. Any problem areas I should look into first or is this something that might be a switch or board issue with the multi functin turn signal switch? Sorry for the long post and thanks for any info you can share!
Edited by sngsht
