Questions about frames and 2wd suspension
So to make a long story short.....a long time ago I wrecked my truck and had the frame repaired. For whatever reason I still feel weary about the frame situation because of who did the work.
I recently found a guy who has a 2001 dodge dually frame and front axle. I have pictures of it but his front end setup is more or less a solid front axle with no differential and it has coil spring towers on the frame
My current pickup a 1997 dodge 2500 single wheel 2wd has the old control arm coil spring setup.
My question is is one or the other a better front end ? And if I could score this frame and stuff would all my 97 stuff be able to be swapped to that frame?
