AirDog 150 in cold weather
when temps dip below 30 i will NOT buy fuel unless it is at a truck stop, aka pilot, flying j, Travel America etc.....  i have also taken to mixing power service with the treated fuel....  no issues since started doing this....
as to heating the fuel in the tank, the OTR trucks have coolant heaters for their tanks that plumb in and work with the block heaters.  they keep both the engine and the fuel tank from freezing....
just food for thought...
Just an update here, now that the temps are way low like -10 with wind chills to -40, my filter heaters are keeping me running. The fuel psi still drops but never below 10psi. When I idle for about 20 mins the psi starts to climb back up but once I give it some throttle, it drops back down again. I am heating both filters.
Where did you get your heaters from?
For the small filter I bought it off eBay. It is one of those orange WVO heaters. On the other filter I was given a filter heater for a semi. That one is more of a fabric material vs those orange rubber pads. I have each one wired to its own fused switch in the cab.
