Misfortune with the wind
  • 5 months later...
Hey Mike, did you ever replace the hinges? I've got a similar problem with my truck, the gust swung the door backwards hard enough that the front edge has two little pinches in it from hitting the hinge itself....
Nope never did. Just re-adjust the upper hinge a little and keep going. I was talking to a local rancher and he's got the same problem to I got to get down there and fix his door too. Just light readjustment. I will admit that full hinge replacement is the proper way of fixing the door. If you can get away with a mild readjustment go for it.
