electrical question
I'm not getting power to my dlc checked all the fuses and they're good replaced some anyways to verify. And still getting nothin. I have a check engine light and I'm trying to figure out what it is and I tried the key trick and only get p1693 p done then back to the trip. Any help is appreciated I've been searching for the answer the last few days an nothing is helping really
Make sure the pins are not pushed out of the connector under the dash for the OBDII port, have seen this happen several times. Check that all wires are pushed into the connector and that when you hook up a reader or programmer it doesn't push them out the back. Then you can start pinning out the harness for issues.
