Edge Comp Reset?
Not sure about a "Reset" per say but you can set the sublevels 1-5 within each main level 1-5 . Been a while but I think you need to hold both up and down arrow buttons for a few seconds until the LEDs start blinking then use arrows to adjust sublevel, it has to be done in each level, to set you just use power button and turn it off and on again.
Hold the power switch for 3 seconds and release put you in sub-level mode.
To reset the Edge Comp just try the key off. Then next power cycle it boots back up.
One can't "Like" your posts?
Thanks I knew one had to hhold one button or a combo of buttons, been over a couple years since owning it.
