1997 Ram 2500 4x4 Diesel power windows and fan cut out
Ladys and gentelmen boys and girls experts of all sizes
I have a 1997 Ram 2500 4x4 Diesel with power windows and fan that cut out
a couple of days ago.  Everything else electrical seems to work (although the
airbag light comes off and on now)
Anyway is there anyone that has the schematic for the wiring to this model.
or has a good idea as to the solution.
Is there a breaker or something that I am missing.  All fuses and relays under the hood
and on the driver side fuse panel are good. Blower relay is fine (under steering column)
Any help would be appreciated.  Its getting hot in here with the windows up :cry:
Electric windows have a circuit breaker in the fuse panel on the driver's side of the dash.
Fan motor could be wore out or siezed. Blown fuse. Most likely under the hood in the PDC.
Airbag light is most likely the clockspring in the steering column...
Small donation to the site will get you too... The wiring diagram.
http://forum.mopar1973man.com/index.php?/files/file/65-1997-dodge-ram-wiring-diagramszip/
Fan motor...  drop it to check for leaves & critters.  Fan resistor block...  flollow the power wire back from the motor...  extends up into the heater duct & can get clogged with mouse nest...  blocks air flow & causes resistors to fail.
