idle speed adjustment on 1992 12 valve?
The idle screw is on the back side of the pump (head side), you would screw it in to raise the idle and screw it out to lower it. I believe the lock nut on the screw is 10mm.
Here is a picture showing the idle screw.
bjytech is right. The 10mm wrench will loosen the nut (maybe) like a few I've worked on I've had to use sockets and one I used a screwdriver and hammer to tap the nut to loosen. Make sure you snug that nut back up again. It might be the governor spring getting weak with age why the idle is sagging down.
