Looking for Staff Members
Hey Guys,
So I finally replaced the brake lines on my Dodge. I bought them off the web, and went with this stainless steel kit. Some things to note.
Website For Brake Lines https://www.sstubes.com/
Website for Body Bolts https://www.tractorsupply.com/tsc/product/hillman-hex-body-bolt-5-16-in-18-x-1-in-with-washer-for-gm-ford
These guys were awesome, and the lines came out in a big box, and they were fairly close to the oem ones.
WARNING!!!!!!
DO NOT! I REPEAT DO NOT! Get rid of this junction block.
I made this mistake and found out you cannot get it anywhere. No one makes a repo part!
Here are some photos of the brake lines from them.
The brake line install was fairly painless. If you need to replace the body bolts like I did, they can be found at Tractor Supply Company.
User Feedback
More options...
 I'm assuming this us just remove and replace? Looks like quality lines, stainless is always a great idea if you plan on keeping the truck for a long period of time like most of us here.
 This will get put on the list of future upgrades for my truck for sure.
More options...
   1 of 1 member found this review helpful 1 / 1 member
Completely worth it. I've bought the aluminum "you bend it" bulk brake lines and it's just not worth the trouble unless you have a custom application.
More options...
Great info, I'm thinking of doing this myself as I leave in iowa where salt goes with everything in winter, no shortages of it in sight.
Ads
