All updates beyond this point will be placed in the article for this.  You can find the article here.  Feel free to post and questions or improvements to my writeup.
Thanks
Nick
Article can be found here.
Pre 7/6/15
This will show the progress in installing the he351ve into my 2nd gen cummins.  I will update as I go along.   This thread is not dealing with the controller needed for the he351ve.  The thread that covers the controller can be found here
Parts
__________________________________________________________________________________________________
HX40 style Downpipe click to go to vulcan for the part ($125)
t3 to wgmt flange adapter to mate the he351ve to the t3 exhaust manifold. ($150)
$T2eC16FHJGQFFho+Oh5nBRd)(JgYFw~~60_1.JP
4 Ft of 5/8' coolant hose for your local parts store ($10)
5/8" oil rated hose 2' worth ($5)
10 x 5/8" pipe clamps.
T3 oil drain ( ebay)
2 x 5/8" T fitting ($5) Local Parts Store
HE351Ve turbo ( $300-$600) depending on where you get it.  I would suggest CumminsForum or here of course if one is for sale.
You will need some way of attaching the hotside intercooler tubes/boots to the turbo since the output from the Turbo faces forward rather than down like the 2nd gen turbos.
I went with the charge tube from Stainlessdiesel.com HERE
You will need a  2.75" to 3" reducer and clamps for this to work.
There are also reports that a 45* reducing elbow will work also.  unsure on that but you can try.
First Specs on the Turbos
HX35 56/60/12 60ish lb/min left vs HE351ve 60/68/3-25 right 69ish lb/min
Start pulling the old turbo off
Use PB blaster or similar on the flange bolts for a few days prior to removal.
Double nut the two bottom studs and remove them so you can bolt the adapter flange to the manifold.  The short bots go in the bottom and the long bolts with the nuts attach the holes of the flange.
Next if your truck is like mine (auto) there is a hard coolant line just behind the exhaust manifold that will block the rear most bolt on the adapter flange from being used.  you can see the bolt hole in question.
20150606_102708_zpszk0oa84x_edit_1433608
Use the 5/8"coolant hose and a 5/8" T fitting to remove the hardline and replace it with the coolant hose.  You will need to run this to just in front of the oil filter and also to the output of the coolant line from the HE351ve.
Next you need to remove the old downpipe if you don't already have an HX40 style installed.    this is a PITA to say the least.  I had to cut mine out.  The hx40 style downpipe flange will attach to the back of the he351ve without the elbow.
In order to allow for a more vertical position of the center section I cut off the top of the strut nut.
Center Section installed and coolant hose run to the turbo.  I still need to run the return to the hot line, but I need some more hose.
I used a sawzall to cut the flange off the Oil return tube.  I will use some oil rated hose to connect the turbo to the return line.  You can see in this picture that I just reused the OEM banjo bolts for the coolant connections.  I used a hack saw to cut the braided section off so it was just a solid metal banjo bolt.  I then just pushed the 5/8" coolant line over and used a hose clamp.  I will do an fittings at some point, but for now this will work.
Once the center section is installed,ensure you have removed the alignment dowels from the compressor housing so you can clock the compressor like so
Use the preferred method of connecting the charge pipe, I choose the stainless diesel pipe and a 2.75" to " reducer then reused the oem 3" to 3.5" elbow at the intercooler.   Alighn all boots and tighten down the clamps.
Note the position of the passenger side neg battery cable to the engine block.  I might have to redo this with a new longer cable, I have been meaning to anyways, but I haven't gotten to it.
I used a pfe 5/8" hose to replace the hard metal oil drain.  There is a larger diameter coupler near that block that you can insert the pfe hose into and clamp down to retain the drain connection to the block.
Hard to see in the picture but run the other coolant line into the bottom of the turbo and T into the other heater core line.  Ensure you leave some space between the exhaust manifold and the coolant hose.   You might use zip ties or something similar to hold the hoses together.
  • Replies 47
  • Views 15.9k
So after the first longish trip ( 100 miles) I am pretty happy with the turbo and very mad at myself.......I forgot to tighten the compressor housing all the day tight.  THANKFULLY no damage, but it was causing my high egt and slow spool issues.
I can say however, I can do 65 mph with the veins %100 open with 0 boost and 0 drive.
Did some digging today and found a t clamp that was shot and the lower 3.5 to 3 inch elbow on the drivers side has a tear and was leaking.
I will see how the egts and smoke is after I get those on the truck.
Well I have had the turbo in the truck for a few days.
I have some EGT issues, and haze issues, but I am almost %100 sure that is due to the large cut I have in one of the boots coming off the intercooler.
I am going to swing by a place tonight and get a new boot and get that fixed.
However I have been able to put some 55-65 mph crusing miles on the truck.  I can say that I have 0 issues with leaving the veins %100 open and cruising egt's stay below 800 and I make no smoke.
The code is set to jump out of the pot if I increase throttle above %25 I think, but it is rare I need that even here in the rockies.  I am able to accelerate from a stop light with the turbo open without any issues.
I have put nearly 200 miles on the truck and I have used just over 1/4 of a tank.   some of which was going up a mountain pass and farting around with the skinny pedal.
Here is a couple videos from my drive in.
First one is me setting the turbo small ~5cm to show that you can make 3-4 psi of boost at 35 mph with about 10% throttle.  Then open the veins up all the way and cruise at 55 with no boost no drive and no smoke.
and one with the veins %100 open leaving a stop light.
Alright guys. Is this normal for 100 hp injectors no tuner fueling
Slow roll 100% throttle
He 351 100%:
Free Rev to red line
100 hp injector rev:
This is about % 40 throttle
40% throttle: https://youtu.be/vRP7i0AH5pk.
Well I'm amazed that the VGT did not clear up the smoke but at the same rate I did run a HE351VE for some time. What I quickly realized was in my trucks configuration at the time was the VGT could not flow enough air unless I choked down the vanes quite a bit. The negative was when I let off the throttle with the vanes choked down I would receive a notable and multiple bark.
I was running a Fleece VGT controller and I had created several maps and found anything over 33 PSI of boost I would receive this bark when I let off the throttle.
On modern trucks like the 6.7 Cummins the boost tables, fuel maps and several other parameters are used to set vane position to achieve the best possible turbo response, boost and keep the turbo efficient.
If your running a Fleece VGT controller I still have the maps I may be able to send you so you may program the turbo for better results.
Now as far as smoke levels with your DFI 7x.009 injectors what nozzle style did you use?
I myself am running his SAC injectors and see about the same smoke level but I also am currently running a Borg Warner 62/68/.80 turbo with the FMW compressor wheel. At wide open throttle I do produce a haze and my EGT's are manageable.
Smoke I was seeing was due to an issue with the injecotrs. They were set at ppump preasures.
I am waiting to see if the new injectors fix my issues.
My controller now does vanes based on turbo rpms which helps clean up the smoke too.
Not sure if you can read code but here is what Hakcenter has in place to keep the turbo from barking.
  constrain(vane_position, min_position, max_position);
  final_vane_position = vane_position;
  // Vane smoothing between large values
  if (turbo_rpm < top_end_rpm) {
    if (vane_position >= last_vane_position + 20 && last_vane_position < max_position - 10) {
      final_vane_position = last_vane_position + 10;
    } else if (vane_position <= last_vane_position - 20 && last_vane_position > min_position + 10) {
      final_vane_position = last_vane_position - 10;
    } else if (vane_position - 10 >= last_vane_position || vane_position + 10 <= last_vane_position) {
      if (vane_position > last_vane_position + 2 && last_vane_position < max_position - 2) {
        final_vane_position = last_vane_position + 2;
      } else if (vane_position < last_vane_position - 2 && last_vane_position > min_position + 2) {
        final_vane_position = last_vane_position - 2;
Effectively it will only move the vanes slowly if the last position is > x amount.  So even if the vanes have been told to move a lot, due to change in conditions, it will only slowly move them.
Injectors are back in and smoke levels are down to what I would consider reasonable for the altitude.   Still not really super happy with them, but they are pretty good ( i am overly picky).   I am sure that at sea level they won't smoke at all so that is what I would expect.  I was hoping for cleaner, but I am not sure if that is possible.
Some more fine tuning in place on my code.  I am now "snapping" the turbo closed for a moment then opening back up when you go from idle state to throttle state.
Smoke is much better, egts are down, and DD performance is much better.  I am really starting to like this turbo for DD duties.  The torque curve is vastly flatter compared to the hx35.
Last thing on my short list is to address my turbo overspeed issue.  I am able to push the turbo RPMS to 140-150k without much trouble.  I have been opening up the turbo curve more and more and the issue is getting smaller and smaller, but I still need to find the sweet spot for WOT.
I agree the turbo can provide the air required for the truck to produce a flatter torque curve although it's still limited to 60 pounds of air s minute. At 30 psi it will perform fine once you achieve 35 PSI of boost air the turbo will begin to over-speed due to the engine requiring near 65 lb/min of airflow. Basically producing hot air. If I remember the turbo max allowable RPM is 144,000 that is measuring shaft speed.
I've ran into this issue with my truck. In my case removing the VGT and using a larger turbo has helped gain better fuel economy on the highway but I have lost the low RPM power because of the .80 A/R housing providing boost air around 1450 RPM. I could go down to a .70 A/R turbine housing (12 square CM) to increase boost at lower RPM or change torque converter to a 900/400 from Dave. There are many ways to correct this but for my driving style the .80 housing is is doing great.
Edited by Vais01
everything I have read says the compressor side of the he351 is a super hx40.  Holset says the super hx40 is rated to 130,000 rpm at 40psi and moves up to 850 cfm
http://www.myholsetturbo.com/40appnotes.html
I am seeing much better mpgs above 55 mph with the he351 compared to the hx35. This is because I am able to manually control the vane position with the use of a Potentionmeter.   I am able to do 65 mph with 0psi drive pressure without smoke and with egts sitting around 800*f.  If you need the power, you just have to increase throttle above %25 ( or turn the pot off) and the vanes will snap back down to the rpm based position.
For my goals of no more than 400-450hp it is a pretty good fit.
How do you know what turbo rpms are? What air restriction is its rated rpm at any given rpm?
Altitude, atmospheric pressure, humidity, temperature and a list a mile long will effect this.
I like to use a vacuum cleaner as an example for turbo over speeding and air intake restrictions. Put your hand over the end of a vacuum hose and what does the motor do?  Most will say it works harder because it makes more noise, but in reality is went into a vacuum and is working less hence why the motor sped up in a vacuum state having less to no air to pump and it speeds up, same happens with a plugged air filter, turbo speeds up since it is not pumping air it can not scavenge.
I am using the shaft speed sensor on the he351ve to know what the shaft speeds are.  I am printing that info on the lcd screen in cab connected to the arduino. I can push it past 140k without much hassle.  However the specs on the compressor wheel are not widely know as it is a holset turbo.
Issue I am trying to resolve is keeping the turbo from running outside of its efficiency ranges like you are talking about above, if it is just spinning like crazy it won't be pulling in air like it was engineered to.  Since it is a variable exhaust housing I can tune it to open the vanes just enough to keep it from overspinning.  I just have to tune and test and tune and test .  testing and tuning is the only way to fine tune the setup for my truck.
Holset states the air flow is over 850 CFM and the wastegate preset to 40 PSI. That means if 40 psi is the max preset the turbo can produce a whopping 77 lb/min of airflow and that equates to 1065 CFM of air at 3200 RPM.
This is a massive amount of air from this turbo but would make the turbo too small for the 6.7 Cummins which would require about 80 lb/min and 1107 CFM at 35 PSI of boost.
The tricky part is that with a max pressure ratio of 4.5 that would mean the max boost capable of this turbo at 2800 RPM (Max rated power) is right in the ball park of 40.5 PSI. It calls for 940 CFM and around 68 lb/min.
For a modified 5.9 this is perfect and sets the point on the compressor map right in the .76 efficiency window.
The only thing is through all my testing the VGT and my trucks configuration it could not provide enough boost or airflow to keep the EGT'S below 1300 wide open. This is no problem for my current turbo.
Thanks for the quick turbo math lesson.  Good for my needs haha.
Wild, yep it is pretty nifty.  Makes for coding possibilities that are pretty cool.  Most importantly now that everything is paid for it gives me something to tinker with without spending money.  I still feel I can make the code work better for all around driving.  the rpm maps that I have right now are a little notchy,  keep in mind I am pretty picky when it comes to stuff so most likely wouldn't even notice.
My wife loves that I can tinker without spending money haha.
Been there before. The HE351VE is a different animal all together compared to the HE351CW.
Just a small bit of advice the so called "silencer ring" is not a silencer ring on the HE351VE. It's a compressor surge preventer. There are no compressor map enhancement cuts on the compressor housing like on the HE341, HY35W or the HX35W to prevent surging.
If you tune the turbo correctly upon rapid throttle let off on max boost the turbo should not bark or surge due to back flow. This has to do more with drive pressure than anything else.
I'd like to see a video of the turbo at full boost and rapid throttle lift if you can make one.
Edited by Vais01
It "hiccups" rather than barks now.  I still need  to work out a way to delay the turbo from closing fast on let off.  Shouldn't be hard once I look into since I know what my throttle position is.  I might just raise my walkdown rpm or the rpm that the turbo tried to walk the vane position down so idle rpm is around 12k
I'll try to get a video soon here.
The trick is to allow the vanes to suddenly open up upon throttle lift this prevents the so called bark. It kind of makes a pulsating whooshing noise when the drive pressure is still high. This is another reason I finally got away from this VGT because the inputs to correctly operate the vane controller are immense. Try limiting boost levels to 32 PSI max and see if that helps. That's what I did with mine and it prevented the turbo from barking.
