it's time to buy filters
so i have the filter spread sheet pic that AH64ID had from a few years ago.
it's a bit out dated. so i'm after the current list.
right now i run the
oil LF 9028
fuel f5320
fuel baldwin 7977
as one can see i like the better line of filters. i usually run valvoline 15/40 and or 5/40 pending what's on sale. i only run till about 7500 miles.
my thoughts are going with.
DBL7349
ff5814 if i can find one.
P553203/553207
so what's the best ones to get today.
thanks for any thoughts you feel like sharing.
  • Replies 4
  • Views 2.7k
Most any upgrade is better than "stock" filtration.....................both engine oil and fuel.
Your sig says bone A$$ stock but those filters listed are not for a stock truck... what aftermarket setup do you have?
PF7977 is the best is gets for the OEM cansiter.
DBL7349 is the best for oil
FF5814 and P553203 are great filters, but what are they going on?
That statement is generally true for engine oil, but I would be very careful with fuel on a HPCR as there are plenty of filters being used that are worse than stock.
I think it's a standard 1/14 fuel head, right now it has the 5320 on it. It's mounted under the cab just in front of the t-case.
Sorry bout my sig, it's kinda out of date.
Gotcha. If you just have on additional filter I would run the p553203.
