Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
So, what are some of your favorite tips n tricks you've found over the years? Things that help make your life just a little bit easier.
I'll add more as I think of them. But to start it off.
When you have a chunk of plastic tubing/fitting that broke off at the threads, and you need to get it back out. Use a sickle blade, it works stinking slick.
