Rear brake problem, Disk brakes conversion.. Help!
:shrug:
Posted Image
Posted Image
Can anyone ID this rearend in my 98.5 dodge? Its supposed to be a drum brake but someone previous to me swapped this into the truck, I bought a 2002 caliper and its the same one and the rotor I bought looks similar to the inside 50% of this assembly, Do I need to pull my wheel bearings etc? Anyone in the Vancouver Washington area that can help?
Thanks.
Paul
  • Replies 10
  • Views 3k
Anyone else seen this style of axle before? :shrug: It doesn't appear like mine... (Guessin')
is there an id tag on the axle? it is a short piece on one the the diff pan bolts. it will id the axle and give your gear ratio
---------- Post added at 02:29 PM ---------- Previous post was at 02:28 PM ----------
if you take a pic of the diff pan...i can probably id it
It looks like a Dodge Dana 80 Dually hybrid axle. This would make sense as it would be the easiest conversion. A Ford or GM Dana 80 Dually would have 10 lugs. It could be a Dana 70HD dually but that would be a much harder conversion likely requiring the spring perches to be moved. You will need to remove the entire hub assembly to unbolt the rotor from the hub. The rotor is only the inner half of the assembly in your picture.
Thanks Ed... I knew someone here would know the answer to his issues! :thumbup2:
This looks different than the axle on my 01.5 that came with disc brake rear axle. Hoping not to appear dense, I wonder why your axle was selected instead of the newer one?
Well, now that I have it apart, Its got the worse wheel bearings I've ever handled myself.. And It kills me that I never noticed while driving this beast. ugh. Anyone local to Vancouver Washington that can press some new ones in for me?
Not me... As for bearing those should be standard tapper roller bearing with a tappered race. You should be able to drive the races out with a piece of soft metal rod. Should be simular to this... (2 1/2 Ton millitary fire truck with drum brakes - this was the only bearing pic I could find fast) :banghead: http://forum.mopar1973man.com/attachment.php?attachmentid=709 Should be able to do this with basic tools. When I did this with the fire dept I was using a old chunk of re-bar... :rolleyes:
I'm such a newbie.. I'm tired of it. I had a old friend stop by today and point out that the bearings are fine they just "float" in there and when pressed up against the shaft they are just fine and have no wobble. Back to bad brakes I guess. And, the other side was physically broken as well. But, good news was I was chatting with him about the truck and possibly selling it etc. and he pointed out that he's pretty sure that the fuel system has been replaced as in a newer vp44 and lines/injectors as they all looked newer to him and the injector pump had been painted instead of being raw aluminum as well as fresh looking polyurethane fuel line mounts.Do you guys think he's right since the inj. pump has clean paint on it and the lines have poly mounts that the system has probably been replaced?Thanks.
Thanks.
Painted black? High quality VP44's are normally UNPAINTED aluminum. Black painted pumps are from Czechoslovakia and are usually of low grade and life span. Hmmm... As for the poly mount most all trucks came with moly vibration block to tie the high pressure lines to together.
Here is what mine look like factory injection lines. (Donig a RV275 injector install)
http://forum.mopar1973man.com/attachment.php?attachmentid=711
http://forum.mopar1973man.com/attachment.php?attachmentid=710
no, it looks painted silver. I do not see your picture.
---------- Post added at 11:04 AM ---------- Previous post was at 11:02 AM ----------
Now I see them. Thanks. I'll try to snap a picture of mine..
