Setting HX35 wastegate actuator
- Replies 9
- Views 13.3k
The_Hammer 5 posts
Cowboy 3 posts
TFaoro 1 post
My wastegate actuator quit working so I ordered up another one on Ebay. With the turbo off the truck I've been playing around with the rod adjustment. So far I've managed to stave off boost creep until 25psi whIle still fully opening the wastegate at 33-34 psi. This is without a boost elbow.
Can anyone think of an issue with adjusting the rod this way? I wouldn't think there would be an issue as long as the wastegate fully opens at the desired psi.
