- Replies 9
- Views 3.8k
Mopar1973Man 2 posts
silverjim 2 posts
JOHNFAK 2 posts
white01 1 post
After reading a lot of advice on this and other forums, I decided that I needed to buy a fuel pressure gauge. Going on recommendations I’ve received, I ordered an inexpensive Westach gauge. When it arrived, I had a local garage install it. After they finished, I got in to drive the truck back home, a distance of 25 miles. About 7 miles out, the gauge went to zero. I pulled off, shut the engine off, and thought about it a bit. I started the engine back up and the gauge went back to around 11psi idle. It worked all the way home. The next day, when I started it up, the gauge was zero and stayed there. I called up the garage, and they said to bring it in Friday. I called up Geno’s Garage and they said to have the mechanic check all the wiring. OK, I said, and headed off to a town about 50 miles north for some necessary grocery shopping. The gauge read zero all the way up and back, but the engine felt like it normally did. Geno’s Garage got back to me and said that the lift pump itself might be bad. I didn’t think the truck would run without the lift pump running. I took the truck into the garage on Friday. The first thing they did was to put a mechanical fuel pressure gauge to check. Damn, the lift pump wasn’t working at all, so I had to have them replace it with just the standard one. Small town. The garage didn’t know if the lift pump not working would have damaged the fuel pump or not. The diesel fuel tank was from full to 3/4 up and back. I’m content to drive along the winding two lane road around 55mph or so, going through two small towns on the way. I probably drove a distance of 170 miles with the fuel pressure gauge reading zero. Is there a way to test the fuel pump to ascertain if it was damaged or not? I realize that going without the lift pump certainly wasn’t good for it, but our normal camping is often in rather remote areas, far from cell phone towers or anything else. Are there any thoughts out there to estimate the chances that the fuel pump was damaged? Thanks for any and all answers.
