Factory keyless entry
Hello,
i have a 1997 ram 3500 Laramie plus package. So I have the tan leather interior with wood grain which I'm told is very rare for a 12v truck. I found a truck at a local junk yard that is a 1997 that has factory keyless entry and I was wondering if anyone ever added factory keyless entry to their truck or if someone has a wiring diagram of how the keyless entry is wired. I basically want factory keyless or no keyless entry. I'm not really into the aftermarket ones, it might be the easier route but that not what I want.
Edited by andrestauder55
  • Replies 23
  • Views 8.6k
  • andrestauder55
    andrestauder55
    If anyone wants I can draw up a diagram and make I list of needed parts. I have about $30 in it all together
  • andrestauder55
    andrestauder55
    I guess I will have to pull both harnesses to inspect the difference between the two
  • andrestauder55
    andrestauder55
    Update : I just got done installing everything and it works as it should
My 02 has key less entry but no security system. That I believe was an option.
Interesting so yours all it does is unlock and lock the doors ? I will look at my build sheet to see what it says.
Edit: Just looked and its listed as two different options not even one after another on my buildsheet.
remote keyless entry
security Alarm.
Edited by moparguy55
security Alarm.
I only have the keyless entry.
