Boost fooled and my Diablo Power Puck??
Hay all. I've had a Diablo PP, boost elbow and boost fooler for quite some time. Recently the fooler died so I removed it. I still can get boost over 27, yet I don't throw a code? What am I missing? I thought I'd get a code after 22? Or will I have to maintain 22+ for a certain amount of time ??
Thoughts?
Thank you.
  • Replies 5
  • Views 2.3k
Does the power puck plug into the map?
If it does then the power puck is boost fooling
No. Just into the pump harness. I wonder why I'm not getting codes??
thoughts?
Map might be unable to read higher than x psi due to age?
Mines been around 30 psi plenty of times and it's only thrown an over boost code once. I'm sure there's a certain amount of time before it sets a code.
Also mine didn't turn the check engine light on, only showed up on a scan tool.
Thanks Buzzin. I won't worry about getting another fooler. If it doesn't put my truck into limp mode then I have no problem with clearing a code every now and then...
thanks again.
