Steering gearbox input collar won't seat
- Replies 12
- Views 2.4k
Austin 6 posts
Mopar1973Man 4 posts
JOHNFAK 2 posts
Hello all,
I purchased a reman gearbox today and was very close to completion when I ran into a problem. The input collar that comes down from the telescoping end will not slide over the splines on the gearbox. I line the flat edge up with the corresponding side, wiggle down, and it only goes down about an 1/8 inch or so and sticks. I tried expanding the collar with a screwdriver thinking it was too tight from the previous box, but that doesn't seem to work either. I've cleaned up the splines really well and sprayed a bit of WD-40 as well with no luck. I have since stepped away for the night as the frustration began to build. Am I forgetting something simple here? when I slid the collar back off the original, it went right back with no issues, so I don't see why it would be so tight. All help is greatly appreciated!!
Austin
