- Replies 3
- Views 1.9k
Mopar1973Man 1 post
Austin 1 post
Cumminz 1 post
Hey all,
I have found that the deeper I delve into this site and others I learn just enough to get me into trouble, and then dig even deeper to find a fix.
My question is, what problems might you suspect if you: A) let batteries die, or B) took APPS off to test, and then did not do a reset of the APPS?
I ask because I have done both without resetting, and had started getting issues related to one of our favorites: Tourque converter lockup. I have done the reset now and SEEM to have solved the issue... At least for now, we will see if it comes back. As far as the alternator, I do not currently have a voltmeter in the proper range to test for AC noise. So I took alternator to get bench checked and it checked "good" with an AC ripple of .45V. I asked them to test two new alternators out of the box with similar readings in the .4V range. I read a good article here that said the tester's internal components can provide some of that effect as well so I'm not yet convinced mine is bad as I have not been able to test it as recommended here. Any and all advice/ideas are more then welcome. I come back to this site time and time again for the superb articles and experts weighing in with their two cents. Thank you all!
Austin
