- Replies 2
- Views 2.1k
Mopar1973Man 1 post
JD63 1 post
Hi I just changed my hyd clutch assy thinking it had failed and that wasnt it so i pulled the trans and found the clutch was finished ,so i put in a new southbend 13125ok assy. now its hard to put into first and second and grinds going in reverse its like its not fully releasing but then it seems to shift good through the rest of the gears on the road . the trans seemed fine before i had the clutch crap out. This is on a 98.5 dodge 1 ton cummins with 110000kms 70000miles it does a lot of clutch work and short trips. any ideas? did i creat my own problem or is something else wrong.Thanks JD63
