Larger Tires Causing P0501 code?
- Replies 17
- Views 6.3k
CLAUS1 9 posts
Mopar1973Man 5 posts
Hawkez 1 post
Frankstein 1 post
2001 Dodge Ram 3500 5.9 cummins diesel. I have code po501 and after thinking back this Code started right after I changed my tires from 31inches tall to 35inches tall. I did any way check ABS Sensor/Replaced anyway. VSS/Replaced it anyway. Apps sweep test, test perfectly Replaed it anyway. So I am back to It has to be a programming issue with the ecm/pcm. I had dealership inter in the correct tire size and set the RPM's @800. Gps we will say shows 71mph when the dash speedometer reads almost 69-70mph. Is there a different setting the dealership should be doing also?
