Brace Box
Got the death wobble going when I hit a bump wrong, so I suppose it's time for a brace box.  Is one as good as another, are they all the same or is there some to stay away from?
  • Replies 25
  • Views 6.6k
  • Royal Squire
    Royal Squire
    In my experience, you probably have loose front end parts, possibly the track bar.
  • It would be best understanding what year/model truck you have, how many miles on it, whats done to it, and any other modifications which may allow members to help better.
    Sector adjustment is on the top side of the output shaft. Typically its a Allen bolt in the top with a jam nut holding the adjustment. I typically run it to the bottom and then back off about 1.5 turn
If you have a lot of steering wheel play and the suspension and steering items are in ok shape don't forget the steering column bushing. In having someone move my steering both with truck running and without and me looking I found the following on mine causing issues listed worst to least:
  • tie rod ends
  • column bushing (have the clunk also)
  • intermediate shaft
  • steering box
If you move the steering wheel a lot and that movement doesn't seem to make it to the intermediate shaft then the column bushing is your honeysuckle.... mine was horrible and it's a well known issue with a fairly easy fix. Got my new bushing this weekend and hope to get it in next week.
Edited by jlongjohn
2 minutes ago, Mopar1973Man said:
@jlongjohn if you wouldn't mind making an article of the bushing install?
Absolutely, I have actually started taking pictures and some video of all my adventures. I would be happy to write up an article. Used to do it all the time for my other passion, atv's...
  • 3 weeks later...
Thanks MUCH Gentlemen!!
Guess I'll give it a go on the adjustment part...
There is no clunk in the steering wheel/shaft that I can detect...I did have the intermediate shaft replace about 2 years ago.The Local mechanic (here in Goldendale, Wa) wanted at least 2 hours @ $85 per hour to see if He could adjust the steering box and to install 3 tranny linkage grommets..That seemed a bit steep to Me!
There is a Les Schwab and a Good Year Dealer here as well, as well as another couple Garages here...Goldendale is not a very big town as You might have guessed by now!!
Pardon if My ignorance is showing, But is there a post/section that would have pics showing how/where to adjust the Play  as described above?
Thanks very much Guys!
Ed
PS: Just want to say a Big Thanks to everybody here...My hind wheels are draggin quite a bit while recovering from a 3rd spinal fusion...needless to say it is going to be quite a while according to the Neurosurgeonuntil I can get back into the harness doing Radiologic Technology.
While I was in the hospital recovering from an earlier fusion, My Wife's neck was injured in an MVA, so She Her career as an Egistered Dental Assistant was ended.
Sector adjustment is on the top side of the output shaft. Typically its a Allen bolt in the top with a jam nut holding the adjustment. I typically run it to the bottom and then back off about 1.5 turns and lock it down. Make sure your nut is loose enough that you not seating on the nut giving a false bottom.
Image result for saginaw sector adjustment
This is the bearing preload adjustment.
As you can see there is plenty to adjust on these steering boxes and don't require replacement all the time. If the box is old and lots of miles I suggest talking to Ryan @ Blue Top Steering and getting a seal kit to rebuild your steering box then you can adjust it up tight once again.
