- Replies 18
- Views 6k
2500ctd 9 posts
AH64ID 7 posts
Wild and Free 1 post
TFaoro 1 post
On my 02 with auto and 3.54 gears I had an Edge Comp hot unlocked HRVP44 BD 155 injectors and an II silver 62 dynoed @ 560 hp and it was a riot on the street. No need to be any higher I had limited sl
Since you have a touch UDC Pro is the way to go.
For the 03-07 #1 is the greatest timing. I had to double check as it's the lowest timing on VP trucks. I turned down the timing on my 01 when I towed heavy. Didn't realize I was running the most timi
Guys, need some input, which will help me decide which way to go from here. Try to follow....
I have an 01 Ram that is sittng until I fix the front end. Body damage and front frame rail is tweaked, deciding on how to fix that still...
Anyways, Truck has a HTT 62/65/12, This turbo was destined to be a top turbo for this truck.
I got an 05 Ram, since I wrecked the 01...Currently just a Smarty on it. I'm getting twins.
Most bang for my buck:
05: I say take the 62/65/12 from my 01 and install it on a 2nd gen exhaust manifold, over something like a s475, or could I go to an S480? Limiting thing on the 05, is I dont want to have to run dual CP3's. How far can a twin with a 62 top take me? If possible Say maybe break into the 700hp range?
IIRC the 62/65/12 should be wasted, if so, and if used in a set of twins, is that gate enough flow? Reason being, I'm doing a 2nd gen manifold swap as well as a gated manifold.
Or down the road...buy a 2nd gen T4 gated manifold, get an S480 to run with the stocker, then later on switch to a S464/S480. (more of a dream)
01: the 62 was initally for the truck with a s475 under it. I've read stock SO VP's usually run outta fuel with a twin setup like that. However, I now have an 05 HE351 turbo that I could run over an S475. Been outta the 2nd gen realm, what numbers do they get out of an he351/s475 on a VP truck?
