- Replies 6
- Views 1.9k
jlbayes 4 posts
Mopar1973Man 1 post
IBMobile 1 post
Have an interesting issue that has become present over the last couple of weeks. So this only happens with low beam. They either will not come on or flicker once and go off. As soon as you trigger the high beam. All is fine. Just for giggles I swapped in a set of halogen bulbs, still does it. Then a set of pnp hids with a dual relay harness. Same deal. I am thinking a power feed issue with either the head lamp switch orrrr multifunction switch. My moneys on the multifunction switch.
