Had something weird happen that I'm having trouble figuring out. Psi on the quad is off 13-14 psi but that just started. Was always off 1-2psi but parked my truck late one night and left my dome light on and then in the morning truck started fine but psi was off more now and even displays 13psi when truck is off but ignition is on. Thinking maybe a lower starting voltage invited a gremlin in. Maybe reflashing the quad will fix? I know I can adjust the boost offset but since it just happened I'm thinking something else is needs to be looked at.
Edited by dirty830
