2010 2500 Ram 6.7 Issues
- Replies 12
- Views 3.8k
MtnManMegaCab 6 posts
Mopar1973Man 4 posts
IBMobile 1 post
Killer223 1 post
So I'll start by apologizing for having my first post be a cry for help, but that is pretty much where I'm at. I stumbled upon this forum while doing some research and to get you up to speed, about a month and a half ago I traded in my 2015 Silverado 1500 that ran perfectly fine for what I thought was a good deal on a 2010 MegaCab with a 6.7 that had been deleted, had aftermarket Headstud's, with an H&S Mini Maxx tuner, so about a week an a half of driving it occasionally around town dropped the youngest one off at school and came back top the house to grab something and went to leave and the truck was completely dead, no power at all. I get to looking and the drivers side Positive terminal clamp was beat to hell, cracked, and corroded pretty bad, so I clean them up, jump it off and drive it to the parts store and put a pair of new batteries in it and everything is fine. 3 days later I am driving through town and the radio cuts off, lights and whole dash start flickering and it starts sputtering then loses all power and luckily roll up to my friends driveway. I get it towed home,2 weeks later have a new mil spec bolt on clamp with a ring post made for the Positive cable, the one that runs to the starter solenoid, and put it all back together then go to jump it. The truck powered up and everything was normal on the dash, the Voltage indicator dropped slightly while cycling the plugs, but once it cycled it went right back up to almost 14V but it would never turn over. It sounds to me like the bendix is engaging but it's just not firing at all. I have the batteries hooked up to a charger right now, but what else in the world could it possibly be? By power of deduction I don't think it's the alternator, the fuses look good, and the connections are good so I am stumped. I appreciate any and all help, and apologize for being long winded but I figured you'd want as much info as possible to help troubleshoot as I am about as green as a gooseberry when it comes to Diesel's.
Many Thanks,
Levi
