I'm having a problem with tuning my pickup every other video I have watched has so many more options then I do.
quadzilla photos.html
Edited by Currey2000
  • Replies 11
  • Views 2.2k
  • Ensure the build data sensor has a value in it.  that's the easiest way to know if you have V2 loaded on the box.
please post the pictures and info you sent on facebook.
pictures dont work
I took screen shots and loaded them
Your vehicle profile is what filters the tuning profiles.  Right now you have the V1 tune profile selected.
Have you loaded the V2 flash onto the box under the hood?   You can see the V2 tuning profile by selecting "V2 dodge 1998-2002" from the vehicle selection menu in the Iquad app.  However you need to match the profile to the flash you have on the box under the hood.
Here's V1 tuning
Here's V2 tuning
Here's how you setup your computer to flash the box under the hood with the "base flash"
The base flash files, including V1 tunes are found here
https://mopar1973man.com/files/categories/
wow I didn't realize that..... so I just have to pretty much set it up again using the V2?
Can you give us history on what you have?  Does the box have V2 tuning loaded to it?
yes I just bought this set up not even 3 weeks ago. I switched from a smarty touch.
yes all of this is brand new I just did not go down far enough to select the V2 tuning.
